Person in the work task not appears
I was tried to running work order and the person who responsible for the task was define ( see attachment "Assign to")
i was assigned Skill with related responsible user/person ( Prepared By, Reviewed By and S.Approved By)
The workflow running smoothly, but Skill Name appears at column "Who"  in the work task list instead of Person Name ( see attachment "WTask").
how can i displayed person name / user name at column ("Who") in the work task list ?
best regards,
  • Hi Bambang,
    Looking at the screenshot you shared, it looks like it is working correctly as all the task are Forthcoming and sent to Skill Name, once it is Active and any user accepts the Task, it should show the user name after a refresh. Please try to accept and complete OLPLTASK01 and make OPLTASK02 Active and see if the WTask table shows differently.
    But answering to your question, you can log in to Layout editor from the Application server and go to work order > Class required > View tab > Select Relationships > Highlight Work Tasks from list > Select WHO.
    Once you are here, you can change the layout as what you want to see inside the table.
    Let me know if you still any further assistance.
    Manav B.
  • Hello Manav,
    Appreciated for your response.
    I was tried to select "Who" in work order relationship but it's still not works.
    best regards,
Reply Children
