eQL Limit Fixed Value attributes
I am trying to write eql that uses a Fixed value list as a paramerter.
For One parameter I want to list only the Active values in the list.  "Active Treatment Plant"
For another parameter, I want to list only the Inactive values in the list.  "Inactive Treatment Plant"
This is what is supplied when I click on Get Value from a Search.
START WITH Document
SELECT
   Attributes["Global""TREATMENT PLANT"].Value col1,
   Attributes["Global""TREATMENT PLANT"].Value col2
WHERE
   Attributes["Global""TREATMENT PLANT"].Value LIKE @StringValue
ORDER BY
Thanks for any support in advance.
