Automate process of "Update Number"
I have created a calculated mask on a template.
'WKR_ORDR-' + Attributes["Global", "WORK ORDER NO"].Value
Because a skeleton document is created from the document template first the default mask is used when you first create a document from the template.
You are forced to click on "Update Number" to force the system to recalculate the number using the calculated mask.
Is there a way to automate this process?
Can this be automated through extended behavior and automation Configuration?
If so can someone point me in the direction of how?
Thanks for any assistance in adance.
