Is it possible to use System Management Console or Layout Editor remotely for a MaaS deployment of the latest version of ALIM by logging in through IMS?
Hi Raphael, I believe you can use them but installing System Management Console locally is not advisable as should be installed on the server where all the services are running, though can install layout editor locally to manage Web layouts.
