Hello eB Users,
This notification is to keep you up to date with new hotfixes for eB. HF00322 eB 15.4.1 Server (Build 15.4.1.325) is now available from SELECTservices and addresses the issue where predictive text fields are not working in Internet Explorer 7.
If you have a service ticket open, Support will e-mail a link to the hotfix for you to download and install. If you would like the hotfix please open a ticket on http://SELECTservices.bentley.com/ mentioning the hotfix number and support will work with you to confirm it will address your issue.
This is a General hotfix. We categorize hotfixes as:
Details of the changes and installation instructions are given in the readme.pdf of the hotfix. We recommend you read the readme.pdf to determine if this will help your site, and test all hot fixes on your test system before installing on production.
Kind regards
Craig RobertsonSupport Manager
