A new hotfix is available for eB. HF00328 eB 15.4.1 Server (Build 15.4.1.325) is now available from SELECTservices and addresses the following issues:
This hotfix supersedes these hotfixes: HF00317, HF00322, HF00325 & HF00326
If you have a service ticket open, Support will e-mail a link to the hotfix for you to download and install. If you would like the hotfix please open a ticket on http://SELECTservices.bentley.com/ mentioning the hotfix number and support will work with you to confirm this hotfix will address your issue.
This is a General hotfix. We categorize hotfixes as:
Critical - All users are urged to apply this hotfix as it addresses a potentially serious problem on all sites.
General - Has general applicability and is deemed to be potentially useful to the general audience. Testing is not limited to any specific site environment. Still, not guaranteed to work in all environments and users are recommended to test prior to putting in production.
Optional - Site-specific or has received limited testing. Users are advised to proceed with applying this fix only if they are seeing the specific problem described and only after testing in their environment.
Details of the changes and installation instructions are given in the readme.pdf of the hotfix. We recommend you read the readme.pdf to determine if this will help your site, and test all hot fixes on your test system before installing on production.
Kind regards
Craig RobertsonSupport Manager
Additional settings are needed in the web.config file to enable Launch function on files, the settings are:
<appSettings> <add key="eB.Browser.LaunchParamsDataSources" value=""/> <add key="eB.Browser.LaunchParamSkills" value=""/> <add key="eB.Browser.LaunchParameters" value=""/> <add key="eB.Browser.LaunchParamFileTypes" value=""/> <add key="eB.Browser.LaunchIncludeDependencies" value=""/></appSettings>
