Just a general post to see if there are any active eB developers out there who’d like to exchange tips and code snippets?
Cheers,
Andy.
Just started using eB API it will be great exchanging tips and code snippets.
Chidi
Hope below presentation helps you in understanding SDK.
communities.bentley.com/.../259011.aspx
Aakanksha
Is there any other documentation regarding the eB SDK for 15.5.1 or later besides the presentation file?
I'm looking for a document which drills down to every public class/methods/properties exposed and how to use them correctly.
I'm use to the old way of coding in eB (using eB.Service.Proxy namespace which uses COM+).
This will soon be obsolete as the eB model is changing and will no longer be using COM+
With the new eB model you need to use the new namespace (eB.Data.Session)
Thanks.
JS
