Created revision 001 of a Tag, then cancelled the work flow and attempted to delete the Tag (after realizing the new revision was not needed).
Received the following Error message when attempting to delte:
“Code Exception: The audit property names ‘{0}’ (from type‘{1}’) does not exist in audit property definitions./value},{212}].
This has been duplicated in DEV as well as PROD.
The tag that was giving the error when trying to delete had an attribute value that will error out when we tried to delete the attribute value. We found that although the attribute is defined as single value (not Multi - value), it had a value stored as if it was a multi-value attribute.
Melissa, can you find out if the original tag was created from template? if yes, can we check that template?
Address: Bentley | 10052 Mesa Ridge Court Suite100 | San Diego | CA | 92121 | USA
Answer Verified By: Melissa Ruth
Roberto - This tag was brought over during migration. It turns out this attribute is believed that it should be a multi-value attribute so there is further research being done with the concept of changing this attribute back to a multi-value attribute likely.
