Trying to create the typical Document Approval workflow onmy freshly installed 15.5.1.236 using eB Director I was pleasantly surprised todiscover quite a bit of new functionality in the Object Behavior topic of theDocument Class definition.
From the looks of it this is extremely powerful. Fiddling aroundI was not able to find a way to achieve what was readily available in theprevious version, that is the ability to mandate a specific Approval Templatefor Approving documents of the particular class.
I searched through the documentation that comes with thisversion and it still discusses the Extended Behavior of previous versions (seep. 59 of the eB Administrators Guide), there is no mention of it in the Readmeeither.
The bottom line for me is the need to create a documentapproval workflow, I am not specifically targeting documentation for theExtended Behavior. Maybe in this version there are completely new ways ofcreating such a workflow. I certainly hope this ability has not been left out!
Can anyone shed any light here?
Hope this presentation helps you
communities.bentley.com/.../260016.aspx
Deepti
Thanks Deepti,
unfortunately the presentations you sent still addresses the previous version(s). The Extended Behavior options shown in the ppt are not there any more!
Hi Vassilis,
are you saying that the extended behavior option are not there any more ?
here is the screen shot of that from the version 15.5.1 its same as in previous version 15.4.1
Or did you mean the extended behaviour of a template of the class?
Aakanksha
Unknown said: Hi Vassilis, Or did you mean the extended behaviour of a template of the class? Regards, Aakanksha
Indeed I am discussing the extended behavior of a class template; in my original post I am talking about Class Definition. I can't find the Extended Behavior topic anywhere else, I don't know where Deepti gets her screenshot from but here is mine (ver 15.5.1.236):
Vassilis
