We are getting the following error in our STAGE environment when we attempt to reassign a task to someone else. The error appears to be in a Bentley plugin. This does not happenin production or in our DEV environment but STAGE was the most recently updated from PROD.
It is a 14.6.2 database and is not user-specific.
ORA-20000:Invalid notification event Id ORA-06512: at"EBNMP.EBP_ADD_MAIL_NOTIFICATION", line 42 ORA-06512: at line 1 "ORA-20000: Invalid notification event Id ORA-06512: at"EBNMP.EBP_ADD_MAIL_NOTIFICATION", line 42 ORA-06512: at line 1"
Any ideas how to fix it? (screenshot attached)
We are going to refresh Dev and Stage again to see if this fixes the problem. I'll post an update here if that works or doesn't.
Hi Melissa,
Any update on this issue ?
Deepti
Honestly Deepti,
We did not get around to updating Dev or Stage and I'm not sure if we found the issue or not.
Answer Verified By: Carma De Villiers
