Can someone confirm if the scope of what is captured under OnObjectChanged is the same between version 14 and 15?
I have reason to believe it’s not. For example adding a relationship between a physical item and document was captured by that event in v14, however it is no longer captured in v15.
Appreciate confirmation as to whether this is by design or whether it is a bug.
Cheers,
Andy.
Hi Andy, 14 does not have the two db events OnRelationshipAdded and Deleted. 15 Has these which would explain why that is no longer captured on objectchanged
Hi Andy,
It seems like Derek answered your query.
Please mark his post as "Answered" if it meets to your question or let us know if you need anything further on this.
Swapnil
Answer Verified By: Carma De Villiers
