I have created a dev box with V15.5.1 and HF00341 applied.
When I try and deploy the web I get the following error.
Time Severity Source Message Data10/28/2013 2:09:50 AM 4 Installation The error Filename: \\?\C:\Windows\system32\inetsrv\config\applicationHost.configLine number: 155Error: Can not log on locally to C:\inetpub\wwwroot\Default as user docqnet01\administrator with virtual directory password occurred while executing deployment tasks. 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
Neil,
Firstly the long error code on this occasion, using www.opinionatedgeek.com/.../Base64Decode shows up the same error message that you have posted.
At what point are you receiving this error? Once you have filled in all the details, and you click 'Ready to Install (click here to start)' or is it before this point?
Assuming the issue is when creating the virtual directory, I wonder if it is because you need to launch the web manager using the option 'run as administrator' ?
Please let me know,
Rich
Hi rich,
I click on the ready to install and it goes through the motions and then I get the error.
Hi Neil
is docqnet01\administrator local account or is it domain ?
Gintautas
Hi Neil,
Is it still an issue for you to deploy the web.
I am busy reinstalling my virtual machine and will test this again, if it is till an issue I will revert back
Answer Verified By: Neil Braybrooke
