Please assist. I need to be able to upload a new file to a newly created document in eB using C#.
I noticed the eB.ContentData.File class. Can I use this?
If possible please provide some code snippets or a sample C# project solution.
JS
Note, i'm using v15.5.1
Hi Jemaine,
Yes, you can use eB.ContentData.file class for upload in v15.5.1.
Answer Verified By: Jemaine Shezi
Hi Manav,
Many thanks. This works well.
Happy to help. Have a Great day!
One last question.
For downloading a file I've used:
eB.ContentData.File f = new eB.ContentData.File(file, filePath, eB.ContentData.File.FileOperation.Download,eB.ContentData.File.ReadOptions.AlwaysOverwrite, eB.ContentData.File.WriteOptions.ExternalLink);
f.WriteAllBytes();
f.Close();
What is the function of eB.ContentData.File.WriteOptions?
Jemaine,Here is the option in Core:
public enum WriteOptions { /// <publish type="Internal"/> /// <summary>Copies files from the source destination in chunks.</summary> CopyBlobs = 0, /// <publish type="Internal"/> /// <summary>Adds a file directly from a URL.</summary> CopyURL = 1, /// <publish type="Internal"/> /// <summary>Adds a file directly from a URL, then deletes the existing file from the source URL</summary> MoveURL = 2, /// <publish type="Internal"/> /// <summary>Creates a link between an external file and an object, the file is never copied into the system.</summary>
ExternalLink = 3 }
Jemaine,
If you want to download a file, "WriteOptions" wont work for you, I guess. If it has to be passed, you need to use it as "WriteOptions.CopyBlobs".
As I mentioned, it Copies files from the source destination in chunks.
Manav,
Thanks, this makes things much clear now.
I have no documentation on the SDK.
Usually I would use the following call to extract the file out of eB. With the new API model is there another way to extract files?
eBProxy.Api.get_doc_file(file.Id, filePath, Proxy.file_copy_options.always_overwrite);
