Bulk Transfer Configuration Tool
I am trying to use the Bulk Transfer Configuration Tool for the first time and am having problems getting it to add files to the documents that I am adding.  It is adding the documents fine but I am getting the following text in the log file for adding the file.
GetFileList:  Either from or To column has not got value in this row.
Path mapping for Electronic Files are as follows:
Path on the Server - D:\BulkImports
Path from the client pc (UNC Path) - \\mseb000\BulkImports
File Path - D:\BulkImports\20131217_ScannedCases\temp1\13206_MainFile.pdf
File name in the F column in the spreadsheet -  20131217_ScannedCases\temp1\13206_MainFile.pdf
Columns F - J from the spreadsheet
F G H I J
20131217_ScannedCases\temp1\13206_MainFile.pdf 20131217_ScannedCases\temp1\13206_Development Plan.pdf 20131217_ScannedCases\temp1\13206_Notices.pdf
20131217_ScannedCases\temp2\13206_MainFile.pdf 20131217_ScannedCases\temp2\13206_Development Plan.pdf 20131217_ScannedCases\temp2\13206_Notices.pdf 20131217_ScannedCases\temp2\13506_Notices.pdf 20131217_ScannedCases\temp2\13506_MainFile.pdf
  Ini File contents
#Configuration  File
[DOCUMENT]
PREFIX=N
MIDDLE=
REVISION=
TITLE=O
CLASS=M
STATUS=L
SUBJECT TO CC=
EFFECTIVE DATE=
REMARKS=
TEMPLATE NAME=A
SCOPE=K
FLAG=P
FIRST ROW=2
[ATTRIBUTES]
1=APPLICATION NO,D
2=APPLICATION TYPE,B
RETAIN VALUES=Y
[CROSS REFERENCES]
RETAIN VALUES=Y
[ITEMS]
RETAIN VALUES=Y
[DOCUMENT LINKS]
RETAIN VALUES=Y
EXCLUDE PARENT CHILD=N
[RESPONSIBILITIES]
RETAIN VALUES=Y
[PROJECTS]
RETAIN VALUES=Y
[VIRTUAL ITEM STRUCTURES]
RETAIN VALUES=Y
[CHANGE REQUESTS]
[ROLES]
RETAIN VALUES=Y
[FILE PLANS]
RETAIN VALUES=Y
[TAGS]
RETAIN VALUES=Y
[COPIES]
1=^^^^^F,J,^,,^Proj Plan Index - VIEW,MODIFY
RETAIN VALUES=Y
COPY FILES=Y
OVERWRITE FILES=Y
DELETE OLD FILES=Y
[LOCATIONS]
RETAIN VALUES=Y
Parents Reply Children
