In version 15.5.1 how do I get the results of an eql or report into my basket so that I can export a copy of the files with out having to do it document by document.
The query uses the document name and the project it is linked to so I can't just use the expanded search.
Puublish failed because the file name was too long
You should be able to add results in to Basket by using eB WEB from report result window or even download files without even adding them to basket by using “Get All Files” function (see screenshot below).
You won’t be able to add results to basket using Director or NED in version 15.5, but it was already been raised with Development and this functionality (add results to basket) will be implemented in future release.
RegardsGintautas
Answer Verified By: Carma De Villiers
