Hi Folks,
Have a 15.6 eB server and have installed the Projectwise connector.
Projectwise works perfectly using the eB server as a gateway. I can see the Projectwise folders in the SMC.
However when I try and add a new Projectwise datasource the values for the datasource dont appear. They were there previously and seemed to have disappeared.
I have reinstalled the eB connector binaries to no avail.
Any ideas would be gratefully received.
Cheers
Hi Commander,
Just to make sure I understand the question, are you saying that your eB server is acting as a gateway server for more than one ProjectWise database. And once one datasource has been added, then remaining ones do not appear when clicking the add data source button. If so, I will need to set this up will confirm my findings.
RichT
Hi Rich,
The eB 15.6 app server is pointed to a Projecrwise datasource. So it has the Projectwise Gateway & Project wise Explorer installed. These work fine and Projectwise explorer goes through the gateway no problem and works.
I then installed the eB Proejctwise connector. The Projectwise folders show up fine in the SMC.
I then decided to add a Projectwise Data Source in the SMC. The usual box popped up and it recognised the Data Source. Unfortunately I then got distracted and decided to finish the config later and closed the prompt thinking nothing of it.
When I came back to finish setting up the Projectwise data source in the SMC , pressed the icon and the same box was displayed but the entry for the data source was missing / null
So now I cant proceed with my config.
Commander
Fixed
Created a storage device and seems fine now
Answer Verified By: Commander Kruge
