Question....is it possible to bulk deactivate eB user accounts using the bulk upload spreadsheet, in the 'Persons' tab? I have all these leavers that are still in eB and I want to be able to deactivate them in bulk. In the spreadsheet there is no status tab that I can put 'Active' or 'Inactive'.
Hope someone can shine light on this.
Many thanks,
Cat
Cat,
I have also looked at the Provisioning spreadsheets and there is not an option to disable the user. There is no way of updating 'PERSONS' in the bulk update basket options either. So I believe that, if the number of users is large, then running an SQL might the the best solution. I will contact you off-line.
Rich
Given that the numbers of users that needed to be deactivated was about 9-10, I believe that the time taken to run SQL to deactivate the users will take just as long as performing the task manually within Director. But I have sent Cat some SQL which may assist in the future, if there is a larger exodus of users. Hopefully it is nothing to do with eB :)
If any other users have similar requests, please respond to this post.
RichT
Answer Verified By: Carma De Villiers
