Hi Bentley and the forum,
Do you know the maximum number of documents you can send on a transmittal? The basket usually holds 500 documents yes so is it 500?
Thanks a lot, Jules :)
I'll try to find out for you.
Answer Verified By: Carma De Villiers
Thank you Dennis :)
Julie are you getting an error now when you send a lot of documents on a transmittal?
Hi Jules,
I checked different documents and videos, but dint find the limitations towards Transmittals.
May be you can try with maximum numbers and check for the same. :-)
In the mean time I will try to confirm it with the engineers.
Thanks Manav, I will ask the team here. They thought it could be 500, sounds maybe correct I suppose. Thank you for your help Manav and Dennis! If you could find out (if there is a maximum) that would be great thanks, but in the meantime I will say no exact number, perhaps 500.
