Bentley,
When I'm on an approved document that has a new not approved revision, why isn't there an option for "Create Change Package"?
I'm asking because I can create a CR and then go to the edit mode and add the approved revision and receive the log/implement/ignore screen. I would assume that the same functionality would be available for the latest approved revision of the document when the user selects "Create Change Package" (if the option was available). I can submit a ticket on this as well, but thought if anyone had any insight as to others having the same issue or same request- it would be helpful.
Kelly
Answer Verified By: Carma De Villiers
