NSG changed 1st April 2019 - Urgent NSG load required.
Dear User
We were advised by GeoPlace that there were several changes taking place this weekend which meant our customers are required to do a NSG load.    We have found that the blank files supplied by GeoPlace did not remove any data so Bentley have created their own stripped files which must be loaded prior to loading the new NSG files (1260 and 1265).  The stripped files can be downloaded from here;
https://bentley.sharefile.com/d-s769e667549541739
See below information about the change which was supplied by GeoPlace.  The latest files 1260 and 165 should be download from GeoPlace and loaded into your live application.
Authority Changes
There are a number of changes taking place to existing authorities in the South West on the 1st April, which will require your NSG data to be updated in order to correctly send and receive notices.  The following three authority codes will cease being used
1245
Dorset [County]
DR
1250
Bournemouth
CV
1255
Poole
FR
There will be two new Unitary authorities then created, one Unitary consisting of Bournemouth, Poole, and Christchurch (previously part of the county authority of Dorset) and a second Unitary formed for Dorset (now without Christchurch).  The following authority/SWA Codes will be applicable to the new authorities and entirely new NSG files will be published
1260
Bournemouth, Christchurch and Poole
B2
1265
Dorset [Unitary]
B3
