Is there a way of globally updating an asset based on another attribute within the same asset based on size?Example:
A gate is 1.2 m wide. (The width being a numeric field in the asset metamodel) Needs its Actual Value updating (again another numeric field in the metamodel)
But we need to update all Wooden/Timber gates using the following crieria
Timber Gates < 1.0m = £ 500.00
Timber Gates >1.1 and <2.0 = £1000.00
Timber Gates >2.01 and < 3.0 = £2000.00
etc......
Mark
Hi Mark It is not possible to do this through the application as it currently stands but would be possible through a script which Professional Services could provide. Regards CT
An enhancement request (reference number 242092) has been raised requesting that form NM0530 be modified to allow an attribute to be updated based on a complex query of other attributes for the same asset. Until this is provided within the application a user can perform the task with options currently available replacing an old value with a new value, or call in Professional Services to provide a script to deal with banding type updates based on another attribute of the same asset type. Regards CT
Answer Verified By: M J Davies WSP
