GPS connection cutting out intermittently.
A customer is using MapCapture. This is based on Bentley Map V8i (SELECTseries 4), which itself is based on Microstation. The number of MapCapture users is very small, so I will ask my question here, because it is about the GPS functionality which is identical to the one in Microstation.
They use MapCapture on a tablet PC running Windows 10 Mobile. GPS device type is set to Windows Location Services, as the tablet PC has not got an internal GPS antenna.
Problem is that the “GPS signal” (virtual, as we are talking Windows Location Services) frequently cuts out, indicated by the GPS Connection Status’ green circle becoming red. This may happen after 5-20 (varying) minutes of use, during which the GPS worked, after which it is very hard to reconnect.
They also tested an external GPS antenna (“GPS mouse”) connected via Bluetooth. In this case they used the real GPS signal, as opposed to the Windows Location Services signal before. Same behaviour, which is strange, as it is using a completely different kind of input now.
Location is northern England, which should have sufficient mobile phone network coverage for Windows Location Services.
Anybody has had similar experiences like these?
Cheers, Kai
