Good morning,
I've just been asked to supply a network shape file to a colleague with fields that are supplied when I run the export. My question is, can I select what fields are selected (as the ones I provide to colleague might not be neccesarily need on a month to month basis) in the export within Spatial Manager or is this something that you have to change your end?
The extra fields include road type, footway hierarchy, adoption status et al.
Thank you for any feedback
You can select what fields appear in the export. After you login to Exor using Spatial Manager follow these steps:
Hope this helps.
