Hi All.
New to this forum, and would appreciate any help.
We use exor assetwiseonline to login jobs.
All was going well ,until yesterday , when there was a Java update to 1.8 Version 131 ( Before that the Java was 1.80 Version 121 )
Launched the application and got an warning about one of the web addresses formssolo03.assetwiseonline.bentley.com
Added this to the Exception List
Re-launched the app - was able to get through , until I had selected the job and wanted to load the links- At that point the app hangs.
Clearly the problem , is that the Java Update is causing a problem
I uninstalled the Java , and re-installed the older version
It took me sometime to find it , as the Oracle /Java download is not user friendly to find older versions
- but that seem to be backward step.
I can get so far.
But when I would expect the Java plugin to load - I get nothing.
Therefore
1. Can anybody offer any suggestions?
2. Where can I get hold of the best version of Java to use with this app , I think it is 1.6
Regards and thanks for any help
James Reilly
Hi Jim, I'll have a try with the latest Java 1.8 version. Please can you give me step by step to reproduce the error? I wasn't sure which part of the application is being used from the description above. Thanks in advance!
View online
If you encounter issues clicking "View online", check here.
You received this notification because you are subscribed to the forum. To unsubscribe from only this thread, go here. To unsubscribe from a forum, please see this note.
Flag this post as spam/abuse.
