I would like to download a particular fix, can someone direct me to the appropriate place, thanks.
Hi Chris, go to http://connect.bentley.com and login as you would to raise a Service Request. Scroll down to the 'My Support' section and click the Software Downloads tile.
Hello again Chris, yes it's been a while! Apologies I forgot to say that for ours you need to click the red 'x' next to 'CONNECT Edition' - it defaults to that but our products aren't available that way yet. So when you first go onto that page, it looks like this:
Click the red 'x' highlighted which will remove CONNECT from the list of filters, then type 'Exor Street Gazetteer Manager' into the Search by Product Name box. This should bring up the screen below - click 'All Downloads' and you should find the one you want in the list.
Hope that helps!Sarah
Answer Verified By: Sarah Willis-Culpitt
Yes, after a fashion! I keep a list on Communities of the fixes we've released against 4.7 and 4.5 versions as they're the 2 current ones. I also create a blog entry every month about the fixes (if any) that we've released that month. On Communities you can sign up for notifications about either or both. For Blog notifications go to https://communities.bentley.com/products/assetwise/exor/b/weblog and click the 'Turn Blog Notifications On' button on the right. For alerts about changes to files, go to https://communities.bentley.com/products/assetwise/exor/m/mediagallery, click the little gear wheel next to the sort options on the right hand side and click 'Turn Gallery Notifications On'.
Sarah
