Hi there,
I am wondering if someone can help me. I have been tasked with getting reports from IM4, I have followed the guides, however when I try and select reports in the Admin area I get an error (see below)
When I find a report that doesn't give me that error when I go to run it I get this sort of error (see below)
Any help on this would be greatly appreciated, below I have listed the types of reports I'm looking for.
I am trying to find reports for;
Cancellation notices
Failed Cat A, B and C inspections
Average duration of works categorised by work type i.e. major, standard, emergency works etc
Fixed penalty notices
Early start agreements
Good afternoon,
May I ask if you have the IM4 workspace installed? In order to verify this, you will need to log into the admin section of Information Manager and ensure the 'IM4 workspace' is mentioned under the configuration.The document 'Information Manager 4 Install and Configuration Guide' mentions how to install the workspace if required.
Kind Regards
Fezan Khan
Sorry for the late reply, at the moment I can't even log into the system to look to see if I have what you are asking.
I there Fezan,
I have been able to get back into IM4 I do not have workspace installed, and I cannot find the guide to help me install it?
Mat
Hello Matthew,
The details can be found in the Install and Configuration guide. Do you have a copy of this? If not, please could you send me your email address in a private message and I shall forward onto you.
Fezan
I have sent you a private message. Please could you take a look and confirm you have received it?
