Just encountered the below issue when adding members to a GOS in NM0110:
The datum element with NE_UNIQUE of 12801 can’t be added as a member of the Group of Sections because there is a GOS record with the same unique id. We are using NM0110 as a workaround because the AWLRS Web App has a defect (Defect Report TFS #1100521). Fortunately, we can still use Spatial Manager and we were able to complete this task. I did a search using the above message and nothing came up in this forum. Has anybody come across this issue?
Hello Pablo,
Thank you for your message. This error message appears because there are two network elements with 12801 unique but they have different network types. In NM0110 please use drop down list to call Gazetteer and select the unique element from there.
Regarding TFS #1100521 Development team is working on this issue.
Best Regards,NT
Thank you!
