I am trying to do an export of the HMDIF files from the UKPMS module in EXOR.
In the version of EXOR we have, there is a module called "HMDIF Export" (this module has a version of 4.5.4.0) - which when you work through the module, it appears to create a template for what you want to export in the HMDIF files.
However, I don't see how you use this template to then actually export HMDIF files.
Could anyone advise? or am I using the HMDIF Export module completely incorrectly?
Anything would be greatly appreciated.
Thanks.
I've uploaded the release notes that include instructions for using the HMDIF exporter here: https://communities.bentley.com/products/assetwise/exor/m/mediagallery/275743
Let me know how you get on!
HI Sarah,
Thank you for that documentation. Seems the HMDIF Export seems to be stuck on an endless loop when I reach a certain point where it flicks between these error boxes.
I also seem to have to come in and out of the module to be able to select the "Network Selection". Any suggestions why this might be?
Thanks again.
Which of our accounts do you work for? I'll need to do some checking of the configuration.
City of York Council
Ah OK thanks! Please can you go into the HMDIF export form then select help / about current form from the menu and send a screenshot of the details that pop up?
