hiya
As a company we hold two separate licences so use two separate database for EXOR, when writing discoverer reports there are more tables abavialbe in the NEDL databas than the YEDL one? Any idea why this is? the ones in the NEDL which are NOT in the YEDL are:-
Tma Notice Errors
TMA Notice Types
TMA Validation Errors
TMA Wors Categories
ali
Hi Ali,
I suspect those tables do exist in the database, if they didn't then you would have problems sending and receiving notices.
The problem is likely to be with the registration of those table in discoverer - the end user layer for YEDL.
I'll have a look at this and get back to you shortly.
Lee Jackson | Product Manager
hiya Lee, any update on this?
Thanks ali
Apologies for the delay, i will follow this up and come back to you ASAP.
Hi Ali
I have located the issue and assigned the 4 views to Discoverer for your YEDL database. Please can you test and let me know if there is anything else missing.
Jodie
I still dont have the TMA Notice Types table in YEDL, this is in the NEDL database
thanks
