Posted on behalf of an Exor user
I have set up a custom layer to view gritting routes and have successfully got it working in Locator, I would also like to view in SM.The layer is available in the TOC but it will not load, "Layer is not loaded". Can you please tell me what I need to do to complete.
Please have a look at the following wiki article: communities.bentley.com/.../layer-is-not-loaded-error.aspx
Pano Voudouris | Senior Support Engineer
No refresh metadata button in custom layers, however I found this at it has solved by problem.
BEGIN
nm3sde.regenerate_sde_from_themes;
END;
