We are trying to set up the location for our Attachements, I thought this was in the 'Product Options' form but cannot find exactly where.
Is there a guide to set this up?
Hi Claire, Kristijonas' answer is right for Document Manager, but I'm wondering if you're referring to TMA attachments. Please can you confirm? Thanks.
Hi Kristijonas and Sarah,
Thank you for your replies, yes, sorry I should have said, we are using TMA.
Claire.
Claire, I found a section in the release notes about attachments, but I don't know if you'll have seen this already? The release notes can be found here: communities.bentley.com/.../269411.aspx. Please let us know if the answer you need is not there and we'll investigate further.
Hi Sarah,
We've managed to set up a location.
Just tried to send a PMR, as we had a problem previously to do with attachments and have had a error;
'TMA-0093; Unable to send the notice: Error in XML (tma_transactions_api.get_request_schema_version) XML parsing failed'.
Can you advise?
Thanks, Claire.
Thanks Claire, glad to hear the location is set up now. I see we have a service request open about the PMR issue so we'll continue the investigation into that under the service request to save confusion.
