When a street record (type 1 to 4) is closed due to redevelopment or similar using the “Close Street” button in SM should the state automatically change to 4?
Currently if the state is not changed first the record has to be re-opened changed then closed again. Leaving the record closed but state as open will generate an error when Geoplace compare LSG to LLPG
I will check this out and get back to you
I will pass this over to our Development Department as I think the change of state should be changed automatically for you if you Close a street.
Enhancement request created and under review by Product Management.
Answer Verified By: Paul Withington
