Is there any plan to address the deficiencies in the word processing sections of Assetwise? These include printed output differing from what appears on the screen (font, paragraph spacing), uncontrollable page breaks, and hidden formatting codes. We spend an inordinate amount of time fiddling with the text to get it to where it will be accepted by agency reviewers.
PDF
Hi Matt,
This appears to be cut off due to the setup of the PDF and restriction of the size of the area given for the output. It would be best to work with the agency owner to address the space constraint issue on the output report - they have all the tools available through the product to expand it.
In response to comments, it is not a printer issue, it is the PDF generation within the application. Users can't predict when the Times Roman font showing on the screen is going to be output in that font or an Arial font in the PDF, or what the line spacing in the output will be - unreliable WYSIWYG.
Understood. Please reach out to your site administrator and they will be able to get the issue corrected.
