ORD Memory Management - 96% used of 32Gb???
Hi all,
Does ORD seriously use this much memory? All I did was create a corridor, open some dynamic sections and generate some drawings and im at 96% of my 32Gb RAM. It all happens in a very short time.
We have experienced difficulties using SS4 due to poor memory management (constant "out of memory" errors and crashes once corridors are detailed) and were hoping this would have been sorted for CONNECT. Unfortunately there's no point going to 64-Bit when all that changes is a higher memory limit that will be exceeded quickly.
Is this something that will be addressed for the commercial release? We are in the process of scoping out some projects for later in the year and have built capability for OR modelling, however, SS4 will never be an option again (based on current limitations and issues) and we were hoping ORD may be ready with at least the SS4 limitations being addressed.
