Find it here: https://communities.bentley.com/products/betas/projectwise-design-integration-connector-for-microsoft-flow-early-access/b/pw-integration-connector-blog/posts/flow-example-upload-images-to-projectwise-using-microsoft-flow-1820117697
HI
generate email notifications based on workflow state change in projectwise share. do you have any example .
thanks
swaroop
We do not have a trigger for a state change yet. As an alternative, you could run a saved search for documents with certain state. Check Flow idea #4: Notify Reviewers and Approvers (Medium complexity)
