Audrius - Would you be able to provide a step-by-step example how to use MS flow to replace the workflow rules engine?
thanks,Kirk Peterson
Kirk,
to learn about available actions, locate Project connector in Microsoft flow portal. There you will be able to see all available actions. All of them are are quite self-descriptive (like Create a new document..). The best way to learn more is add them to a new flow and examine parameters.
There are several more complicated concepts that we document in Wiki pages of this site: https://communities.bentley.com/products/betas/projectwise-design-integration-connector-for-microsoft-flow-early-access/w/pw-integration-connector-wiki
If you will have further questions I will be happy to answer them here.
Audrius
