Hello - I have started to play around with MS Flow and PW. I was trying to use the "Create a new document" action, and I get this error:
Hello, Kirk,
thank you for reporting this issue. We are investigating the root cause of this issue at the moment. I will inform you with the progress.
Best regards,
Robertas
The fix for this issue has been applied. Kirk, could you please verify that you can list ProjectWise Projects without the error?
Thank you,
ok so I selected the connected project, then the PW project, and when i click on the select folder button, I get the same error.
screen shot - web site won't let me upload )https://stantec-my.sharepoint.com/:i:/p/kirk_peterson/ET1XHV1qhMlOviBuipKRh_gBky9hG5M43HJOTyzMfTVqZA?e=GGHLsI
The error indicates that your ProjectWise Design Integration datasource exposed via WSG server is not accessible from our cloud service. Please make sure that your datasource is prepared according to the guidelines in Preparing ProjectWise for Flow wiki section. Your Web Services Gateway endpoint needs to be accessible from the IPs specified in the wiki.
