Hi
I've been trying to use the Get Document File connector to download a list of file from Projectwise.
I first used the Find Documents by saved search action to get the documents I want and this part works fine.
However I keep on having an error when I use the Document GUID as an input into the Get Document File (see screenshot attached)
Is Bentley aware of this issue? Is this something that is planned to get fixed in a near future?
Thibaud
Hi, Thibaud,
thank you for reporting this issue. We were not aware of this and going to investigate it now. Have you tried a different file in the datasource? Are you getting the same error for other files as well? Could you give more information about the file you are trying to download? Have you used any special encoding in the file?Thanks,
Robertas
Hi Robertas
Thanks for your quick answer
I've tried different file type and it is still failing with the same message. What Google told me when I tried to find out more about the Error message was that it may be linked with Projectwise might be in UTF8 and the Azure backend of Flow is in UT16?
Unable to translate bytes [FC] at index 35 from specified code page to Unicode
I am a bit out of my depth here, the end goal is to push files from Projectwise into Projectwise Share on a regular Basis. Mostly i-Models 1.6 at this stage
As an update, the flow is still failing and the error message is now as follow:
This is related to our connector configuration on Microsoft Flow. The fix has been determined and is being deployed. It will take a few days though. I will inform when the Get document file action is working again.
I did some tests today to see if this was working now and I still get the same error message:
Are you able to confirm a date for this issue to be fixed?
