I am starting my own flow, as follows:
Further FYI - the datasource is located in our Bentley hosted environment.
The PW-Find document by search isn't working, and it gives the error as follows:
I am hoping someone can explain the error, and how to fix it.
thanks,
Kirk
Saved Search execution may return errors with some combination of attributes and WSG version. A workaround for this is to run query without environment selected. See if this helps.
This will return documents without attributes, so you may need to query each document attributes separately in a loop.
If the above does not help, let us know.
This example demonstrates this technique: https://communities.bentley.com/products/betas/projectwise-design-integration-connector-for-microsoft-flow-early-access/b/pw-integration-connector-blog/posts/notify-reviewers-and-approvers
Hello - I removed the environment, and I see get the same error. I will look over your example, thanks! Hopefully this will help.
Hi Andrius - What type of value should these be? I am guessing a String or Binary?
DWORD
