My flow using "Find Documents by saved search" appears to be failing - Bad Gateway 502 Error. It works fine when search is configured for extreamely narrow range of documents, however it appears to fail every time saved search range exceeds a few hundered document matching items.
Any advice?
{"statusCode":502,"headers":{"Request-Context":"appId=cid-v1:b708ff59-448d-483f-b1e1-063ddb7fe47e","Strict-Transport-Security":"max-age=31536000","x-correlation-id":"ab6bdfac-17dc-409a-b343-6db163092971","Set-Cookie":"ARRAffinity=45df15217c96d521581cb385bb0e2b0a144929ebf3171b452a3e468370a3cde3;Path=/;HttpOnly;Secure;Domain=connect-projectwiseflow.bentley.com,ARRAffinitySameSite=45df15217c96d521581cb385bb0e2b0a144929ebf3171b452a3e468370a3cde3;Path=/;HttpOnly;SameSite=None;Secure;Domain=connect-projectwiseflow.bentley.com","X-Powered-By":"ASP.NET","Timing-Allow-Origin":"*","x-ms-apihub-cached-response":"true","Date":"Wed, 14 Oct 2020 13:55:38 GMT","Content-Length":"332","Content-Type":"application/json"},"body":{"error":{"code":502,"source":"flow-apim-msmanaged-na-eastus2-01.azure-apim.net","clientRequestId":"ab6bdfac-17dc-409a-b343-6db163092971","message":"BadGateway","innerError":{"statusCode":502,"error":{"message":"An unknown error occurred."}}}}}
I have the same issue (I beleive).
I actually just created a post on this topic --> Timeout Limit Find Document with Search (V2)
Did you find any work around ?
Thanks in advance !
