Power Automate Create New Document V2
I'm trying to use the new action Create New Document V2 in Power Automate and define the values of the document attributes after selecting the environment but I'm always getting an error. The attributes are set up as pick lists in PW which is where the error occurs. For Attributes expecting a text value that works with no issue.
Is there a specific syntax that needs to be followed when there are picklists and I'm trying to pass values through to them using the Power Automate action?
