Customized output reports
Is there any way to get a customized output in CONSPAN or LEAP Bridge? For example if I only want to print stresses at the same 4-5 locations along with some other outputs.  Is there any way to accomplish this?
Parents Reply
  • Hi ,
    As I have mentioned before. Currently it is not possible to get the output of stresses at any particular POI (for example. Only at 0.4L , 0.5 L or 0.6L ..)  . You need to go to PRINT --> Select the span , Beam and then select Positive Envelope stresses or Negative envelope stresses and the program will show the stress information at all the 10th points . The customization is limited to particular Span and beam number.
    Thanks ,
    Vinay
    Answer Verified By: triezenbergj
