Fonts cut off?
There appears to be a font compatibility issue. In the program LEAP GEOMATH V8i, it looks like you should be able to adjust the window in order to see the rest of the menu, however there is no option to move it.
This issue is not resolved by changing the resolution, and the settings are already set to "small icons" in Windows. I ran into a similar issue with STL Bridge and SAP 2000. This was resolved by going into the registry under HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts. I changed the SSERIFF.FON -> SSERIFE.FON.
I suspect this issue will have a similar resolution, but it's a matter of finding which font to change. Any ideas? Or any ideas on which font this program uses?
  • Hi Gokul ,
    This was a known issue in older version of LBE.
    This issue was resolved in V14.00.00.19 which is the current release version available on Bentley select server.
    Please download the latest version and check if you are still having this issue .
    From your screenshot it looks like you are in the Beginners  option . There is an option at the bottom of the screen  called BEG ,just click on that then the program automatically changes the screen to Advanced users and then check if you are still having this issue .
    Try these 2 solutions for now and If you are still facing the same problem then I shall try to find a workaround solution.
    Thanks ,
    Vinay
  • Good morning,
    Any updates on this issue? I know I had a user who had a related issue in STLBridge. This was solved by changing a key in the registry under fonts. Does this sound familiar at all?
    Please let me know,
    Thanks!
    Jennifer Fonken
    IT Support Specialist
    HDR
    1670 Broadway Suite 3400
    Denver, CO 80202
    D 303.318.6299 M 303.917.5077
    Jennifer.Fonken@hdrinc.com
  • Hi ,
    Changes have been made to enlarge the Edit panel and also provision has been made to unlock the vertical splitter which is changeable by the user if necessary.
    In Leap Bridge Enterprise , the position of the Geomath button has been changed so that the button is entirely visible.
    All these changes will be available in LBV15 which will be released in couple of weeks.
    Please download the latest version from Bentley Select server.
    Please let me know If you need any additional information.
    Thanks & Regards,
    Vinay
