Recently I am working on a transition bent which is a multi-column bent. The approaching span is simple span, and the main span is continuous-three-span. I am considering using the 3rd option for live load auto generation since the first two options (one for simple, the other for continuous) are not proper for my case.
Someone please teach me how to use this option 3~ See questions below~ THX
1. The red marked area
This input blocks are always inactivated?
2. The yellow marked area
What are the meanings for each input block? Why there are two trucks and lanes here? The moment input is caused by bearing centerline offset from cap centerline?
3. The blue marked area
What are the physical meanings of these factors?
I tried to find some introduction on this from help file, but I failed. Someone please help~
BIG THX
Answer Verified By: Alex O [Bentley]
