Hello community,I am trying to edit the cross-sectional properties of the elements of a grillage model, in order to simulate the torsional stiffness of a multicellular deck. I have created the web sections using MODELER and assigned them appropriately.Now I look to artificially change the torsional constant and vertical shear area without losing the CS(Begin) / CS(End) definition in the cross-section assignments (and the reference points I need to perform stress checks). Using the "Beam, CS values" in the cross-section assignment to edit the torsional constant dismisses the MODELER cross-section assignment and the reference points are thus lost.
Is it at all possible to edit a cross-section property without losing the rest of the MODELER definitions and the remaining calculated mechanical properties?
Thanks everyone in advance for any input you can give me.
Hi Pedro,
For this purpose there are two possibilities; one is changing the section properties on the cross-section level and the other is changing the stiffness on the element level:
1.) Menu Properties/Cross-sections/Parts:
- Edit a cross-section part in the bottom table
- Apply the reduction factors for Mx, Qy, Qz
2.) Schedule Action Structure change commands / ElemK:
- Factors for Ax, Ay, Az and Ix, Iy, Iz can be applied (Note: Action not applicable for composite elements)
(Press F1 within both windows for more details).
Diether
Answer Verified By: Pedro Natário
