Shear at Midspan: HL93 loading
I'm doing a hand check of shear at midspan of a single span bridge (L = 142').  Loading is AASHTO LRFD HL93.  Based on my calculations, the shear with impact should = 42 kips.  However, Conspan reports 52.9 kips.  Note that I manually input a distribution factor of 1.0 so I could easily compare.   Am I missing something with the load application?  Or with another factor that Conspan may be applying?
