Hi Diether. winzard ( Rm bridge) share files (gp, tcl) example precast girder . thanks
Hi phu, RM Bridge Wizards should be quite self-explanatory by just following the step-by-step input procedure over all the menus. You could even just open the Pre-cast Wizard, check the respective loads you want to consider in the menu "Load Definition" and click "Finsh" to get an example in GP/Modeler and RM/Analyzer.
Answer Verified By: MarcosBeier
Hi Zakaria Mohd Noor Arif,
Yes, you can create model with Wizzard and later edit them in Modeler if you use the option Detach, by right click at Wizard Object name. This will allow you to freely modify the geometrical model references. Just make sure to maintain coherence with all Analyzer data..
Marcos Beier
Senior Technical Support Engineer, Bridge
Bentley Systems Inc.
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 4 days ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
