Conspan 10th points
From what I understand Conspan calculates 10th point increments from the total precast length and not the bearing to bearing span length.  Is there a way to get camber and deflection readouts at the bearing to bearing 10th points?  All the DOTs in New England need the bearing to bearing 10th points for camber and deflection tables shown on plans.
Example:  The total precast length is 72.5ft and the bearing to bearing length is 71.0ft, Conspan reports 0.1L as 6.50ft which is 0.1x 72.5' - (72.5' - 71.0' )/2.  This is a different 10th point than the clear span tenth point of 71' x 0.1 = 7.10'.
Thank you for any help you can offer.
