I am receive the error dialog box below when opening a .csl file directly (double clicking on the file from Windows Explorer to open) from a network drive after updating to latest release on CONSPAN 14.01.00.01.
I can select OK and move on but the dialog box opens each time I open the file directly. The dialog box does not come up when I open CONSPAN first and then open the file from within the program.
Any help is appreciated!
TIA
Sean Keene
Ok, I did that but the same error just from a different location.
And it is not just this particular file it is any .csl file from any location. I did not receive this error message in the older version 14.00.00.19
