Bentley Communities
Site
Search
User
Site
Search
User
Product Communities
LARS | LEAP | OpenBridge | OpenTunnel | RM
LARS | LEAP | OpenBridge | OpenTunnel | RM Forum
hello every one
Sign In
State
Not Answered
Replies
Subscribers
29 subscribers
Views
Users
0 members are here
hello every one
Offline
NagarajRam
over 7 years ago
How do i download this software? Please help to me.
0
Offline
Vinay mysore
Tue, Feb 2 2016 6:28 AM
Which program you would like to download .
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
Offline
Vinay mysore
Tue, Feb 2 2016 6:29 AM
in reply to
Vinay mysore
To download Leap Bridge Enterprise please follow the instruction from the attached Bentley communities link.
communities.bentley.com/.../what-39-s-new-in-leap-bridge-enterprise-connect-edition-v15-01-00-05
Installer Note
How to install & activate LEAP Bridge CONNECT Edition?
Contents:
Installation Wizard
Activation wizard
This section guides you through the process of installing LEAP Bridge on your computer. In order to install LEAP Bridge V8i, please login as an Administrative user. LEAP Bridge can be installed by invoking Setup.exe. If you use Setup.exe, no other special consideration is necessary. Simply follow the instructions that follow. For details on the installation, please refer to the Installation Wizard section in this manual.
Note: LEAP Bridge V8i requires Microsoft .NET 4.5 framework to be installed in order to operate properly.
Installation Wizard:
•First log into the Bentley SELECT Services Web site and download the LEAP Bridge installation kit for the version you have purchased. Please do not download the individual components (such as CONSPAN, RC-PIER, etc.) if you intend to install LEAP Bridge. The LEAP Bridge Enterprise installation package includes the necessary components.
•Once you have downloaded the LEAP Bridge Enterprise installation files, locate the install folder. Run the installer file by double clicking the setup.exe icon.
•You will be greeted by the Welcome screen. Click Next> to proceed with the installation process.
•You are now presented with the End User License Agreement for this software. Please read the agreement and then click the radio button to accept the terms when finished. You may also print a copy for your records. Click Next> to continue.
•You will be asked for an installation location. This is the directory location of the program on your computer.
•The installer now has gather all the information needed to complete the installation. Click Install to finish the process. The wizard begins installing the program onto your computer. Once the process is complete, click Finish to exit the Wizard..
•After the installer completes its process, the program is ready for use. You can launch the program by clicking the Start button and then All Programs > Bentley > LEAP Bridge Enterprise.
Note: Until you have activated a license for the program, it will remain in demo mode and function for only 30 days past installation.
Activating a product using the Product Activation Wizard
This is for installations which use a Bentley Server to authenticate the Bentley SELECT License used to run LEAP Bridge. In order to complete the installation, the SELECT Server Name and Site Activation Key will be required. If you do not have these, please contact Bentley technical support. Without this information the installation will operate using a trial license for only 7 days.
•Install LEAP Bridge Enterprise following the instructions in the Installation section.
•Locate the Bentley SELECT License Management Tool, LicenseTool.exe in the program installation folder (typically the location is c:\Program Files\Bentley\LEAP Bridge Enterprise\).
•Select the SELECT subscriber activating against a hosted (Bentley) SELECT Server option and then click the Next > button.
•The dialog box displays with the Server name provided for Bentley’s server. Complete the Site Activation Key received from Bentley and click the Next > button. Before accepting the entered information, you may also choose to click the Test Connection button to confirm that the entries are correct.
•Enter the SELECT Server name and the Site Activation Key received from Bentley, and click the OK button. If you do not know these, please contact your system administration. Before accepting the entered information you may also choose to click the Test Connection button to confirm that the entries are correct.
•After the information is accepted by the system, the program then displays all the available licenses for your usage as shown in the following dialog box. The license security is now in place. The installation is complete and LEAP Bridge is ready for use.
Note: You may need to contact your system administrator if your organization uses a proxy server to connect to the Internet. Click the Proxy... button in the Product Activation Wizard to display a dialog for entering these connection settings.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
